Hi, Once you have signed in go to the add drop down menu and select 'Add Layer from Web'. A pop up box will appear make sure you have 'An ArcGIS Server Web Service' selected in the dropdown box then copy your URL into the box below. The transparency of the map can be changed using its context menu. Regards Anthony
<!DOCTYPE html> <html> <head> <script type='text/JavaScript' src='http://www.onemap.sg/API/JS?accessKEY=xkg8VRu6Ol+gMH+SUamkRIEB7fKzhwMvfMo/2U8UJcFhdvR4yN1GutmUIA3A6r3LDhot215OVVkZvNRzjl28TNUZgYFSswOi'></script> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Simple Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } body { background-color: #FFF; overflow: hidden; font-family: "Trebuchet MS"; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script language="JavaScript" type="text/JavaScript"> var map; var centerPoint="28968.103,33560.969"; var myLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); myLayer.opacity = 0.5; var OneMap = new GetOneMap('map','SM',{level:7,center:centerPoint,layer:myLayer}); //add one map here function init() { map=OneMap.map; dojo.connect(OneMap.map, "onExtentChange", showExtent); } dojo.addOnLoad(init); </script> </head> <body> <div id="map"></div> </body> </html>
