for row in allRows: if count < 15: tab1Col1Txt.text = tab1Col1Txt.text + row.getValue("DATE") +"\n" tab1Col2Txt.text = tab1Col2Txt.text + row.getValue("CHANGE") + "\n" tab1Col3Txt.text = tab1Col3Txt.text + row.getValue("MADE_BY") + "\n" if count >= 15 and count < 30: tab2Col1Txt.text = tab2Col1Txt.text + row.getValue("DATE") + "\n" tab2Col2Txt.text = tab2Col2Txt.text + row.getValue("CHANGE") + "\n" tab2Col3Txt.text = tab2Col3Txt.text + row.getValue("MADE_BY") + "\n" if count >= 30 and count < 45: tab3Col1Txt.text = tab3Col1Txt.text + row.getValue("DATE") + "\n" tab3Col2Txt.text = tab3Col2Txt.text + row.getValue("CHANGE") + "\n" tab3Col3Txt.text = tab3Col3Txt.text + row.getValue("MADE_BY") + "\n"
Not easily. It can be done with arcpy.mapping but it would require that you author a table outline in ArcMap using line graphics. Then you would populate dynamic text to fill the columns in the table. I'm working on getting a sample out on the resource center. Once I get data permissions, I'll put it up as soon as I can.Attached is a static table graphic (of grouped line elements). There are actually 3 tables, each with 3 columns. I have a total of 3 text elements, one for each column in each table. I read the rows from a GDB table and dynamically populate the text element with line breaks (to create the rows). I can fit up to 15 rows of data onto each table. If there are more than 15 rows, I populate the next table, etc.Here is the code that populates the table:for row in allRows: if count < 15: tab1Col1Txt.text = tab1Col1Txt.text + row.getValue("DATE") +"\n" tab1Col2Txt.text = tab1Col2Txt.text + row.getValue("CHANGE") + "\n" tab1Col3Txt.text = tab1Col3Txt.text + row.getValue("MADE_BY") + "\n" if count >= 15 and count < 30: tab2Col1Txt.text = tab2Col1Txt.text + row.getValue("DATE") + "\n" tab2Col2Txt.text = tab2Col2Txt.text + row.getValue("CHANGE") + "\n" tab2Col3Txt.text = tab2Col3Txt.text + row.getValue("MADE_BY") + "\n" if count >= 30 and count < 45: tab3Col1Txt.text = tab3Col1Txt.text + row.getValue("DATE") + "\n" tab3Col2Txt.text = tab3Col2Txt.text + row.getValue("CHANGE") + "\n" tab3Col3Txt.text = tab3Col3Txt.text + row.getValue("MADE_BY") + "\n"Jeff
Hi Karyn,Do you have access to the Production Mapping extension? There is a dynamic table called the Graphic Table Element that is part of this extension that works well in conjunction with data driven pages. It makes it possible to include a table on your map layout that updates based on the content of the current page extent.David
