public class WebViewDialogFragment extends DialogFragment { // The redirect_uri can be either a special value of urn:ietf:wg:oauth:2.0:oob // or an application-specific custom URI that is handled on the device. private static final String REDIRECT_URI = ""; // OAuth2 client_id = APPID private static final String CLIENT_ID = ""; String username; String access_token; String refresh_token; private CountDownLatch latch; @Override public View onCreateView(LayoutInflater inflater, ViewGroup container, Bundle savedInstanceState) { getDialog().setTitle("Sign in to ArcGIS Online"); final View root = inflater.inflate(R.layout.activity_main, null); root.findViewById(R.id.progressbar).setVisibility(View.VISIBLE); final WebView webView = (WebView) root.findViewById(R.id.webview); webView.getSettings().setJavaScriptEnabled(true); webView.getSettings().setBuiltInZoomControls(true); webView.setWebViewClient(new WebViewClient() { @Override public boolean shouldOverrideUrlLoading(WebView view, String url) { final String code = url.substring(url.indexOf("?code=") + 6, url.length()); AsyncTask.execute(new Runnable() { @Override public void run() { try { requestToken("https://www.arcgis.com/sharing/rest/oauth2/token?client_id=" + CLIENT_ID + "&redirect_uri=" + REDIRECT_URI + "&grant_type=authorization_code&code=" + code); } catch (Exception e) { Log.e(getClass().getSimpleName(), "", e); } dismiss(); } }); return true; } @Override public void onPageFinished(WebView view, String url) { webView.setVisibility(View.VISIBLE); root.findViewById(R.id.progressbar).setVisibility(View.GONE); } }); webView.loadUrl("https://www.arcgis.com/sharing/oauth2/authorize?client_id=" + CLIENT_ID + "&response_type=code&redirect_uri=" + REDIRECT_URI); return root; } @Override public void onDismiss(DialogInterface dialog) { if (latch != null) latch.countDown(); super.onDismiss(dialog); } public void setLatch(CountDownLatch latch) { this.latch = latch; } private void requestToken(String url) throws JsonParseException, MalformedURLException, IOException { JsonFactory f = new JsonFactory(); JsonParser json = f.createJsonParser(new URL(url)); json.nextToken(); while (json.nextToken() != JsonToken.END_OBJECT) { String name = json.getCurrentName(); json.nextToken(); if ("username".equals(name)) username = json.getText(); else if ("access_token".equals(name)) access_token = json.getText(); else if ("refresh_token".equals(name)) refresh_token = json.getText(); Log.i(getClass().getSimpleName(), name + " = " + json.getText()); } } }
// Create and show the dialog. WebViewDialogFragment dialog = new WebViewDialogFragment(); CountDownLatch latch = new CountDownLatch(1); dialog.setLatch(latch); dialog.show(getFragmentManager(), "dialog"); try { latch.await(); if (!TextUtils.isEmpty(dialog.access_token)) { credentials = new UserCredentials(); credentials.setUserAccount(dialog.username, "-"); credentials.setUserToken(dialog.access_token, "-"); credentials.setAuthenticationType(AuthenticationType.TOKEN); return new MapLoadAction<UserCredentials>( Action.CONTINUE_OPEN_WITH_THE_PARAMETER, credentials); } } catch (InterruptedException e) { Log.e(getClass().getSimpleName(), "", e); }
Hi Dan, thanks for the code...
I have created sample app using your code (slightly modified):
I have created sample app showing how to get the ArcGIS Online token without the Android SDK - http://github.com/osedok/AGOLAuth
Please remember to set valid CLIENT_ID in ArcGISOAuth activity before running the sample.
