my List indices are 0 and 1 those are the only two.. Can anyone help spot what's causing that?
import arcpy
from arcpy import env
#set working MDB Here
arcpy.env.workspace = "C:/Users/atimpson/Desktop/Brunswick/PowerPlant.mdb/BPDMLayers"
dataList = arcpy.ListFeatureClasses()
mxd = arcpy.mapping.MapDocument("CURRENT")
lyrlist = arcpy.mapping.ListLayers(mxd)
# Reads a base table and outputs Feature Class and Layer Lists
readTable = open("C:/Users/atimpson/Desktop/ScriptTable/BPWorksLayers.csv")
# Figure out position of feature class and layer in the header
headerLine = readTable.readline()
valueList = headerLine.split(",")
fcPos = valueList.index("Feature Class")
lyrPos = valueList.index("Layers")
# Read lines in the file and append to comparison lists
baseFeature = []
baseLayer = []
for line in readTable.readlines():
segmentedLine = line.split(",")
baseFeature.append([segmentedLine[fcPos]])
baseLayer.append([segmentedLine[lyrPos]])
#Performs comparisons between project data/layers and idealized data/layers
if "BPWorks 2 Layers" in lyr.name:
for lyr, base in zip(lyrList, baseLayer):
if lyr != base:
print(lyr, "is different from", base)
