ArcGIS Help 10.1
An overview of the Hydrology toolset
select Fill
I am new to python.
the python code example for the Fill command starts with "create flow direction" - also when I export my python code from my model that has the flow tool - I do not get the same 'syntax' ( i believe is the word I am looking for) my python code from export looks completely different then the example provided.
my python export from model
# Process: Fill
arcpy.gp.Fill_sa(Dem_Patch, temp2, "")
I am getting an error when trying to create my python code and run it.
ERROR
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
