You can open the layer in ArcMap using the ArcGIS Online, save it to an MXD, publish the service, and hit the service with ArcGISTiledMapServiceLayer class. I have also cached the data using the server cache tools in toolbox, copied the data to the device, and called ArcGISLocalTiledLayer, so I can use the maps offline.http://help.arcgis.com/en/arcgismobile/10.0/apis/android/api/index.html?com/esri/android/map/ags/ArcGISTiledMapServiceLayer.htmlhttp://help.arcgis.com/en/arcgismobile/10.0/apis/android/api/index.html?com/esri/android/map/ags/ArcGISTiledMapServiceLayer.html
I am wondering if it is possible to add an openstreetmap tile layer to a MapView using the Android API? Or is it only esri map servers that work?Thanks
