I am trying to Query a Feature Layer, but only the core ESRI attributes are being returned. How do i get all of the attributes? If i look at the Fields property of the feature layer (_featureLayer below) i am querying, it does list all the custom fields available, but they just aren't returning when i do a query. There isn't a "OutFields" property in the QueryParameters object that I can see...
Query code below.
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryParameters</SPAN>
<SPAN class="punctuation token">{</SPAN>
Geometry <SPAN class="operator token">=</SPAN> TreeMapView<SPAN class="punctuation token">.</SPAN>VisibleArea<SPAN class="punctuation token">,</SPAN>
SpatialRelationship <SPAN class="operator token">=</SPAN> SpatialRelationship<SPAN class="punctuation token">.</SPAN>Contains<SPAN class="punctuation token">,</SPAN>
ReturnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
_featureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ClearSelection</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> queryResult <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> _featureTable<SPAN class="punctuation token">.</SPAN><SPAN class="token function">QueryFeaturesAsync</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> queryResult<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ToList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> item <SPAN class="keyword token">in</SPAN> features<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//*** EACH item has only 7 attributes, and they are only the ESRI core ones</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
