This should be pretty easy. Use a function to actually populate the content of your infoWindow. First, create your infoTemplate: var theTemplate = new esri.InfoTemplate(); theTemplate.setContent(setPopupContent);Next, set up your dojo.connect for clicks on the features in your layer: //Listener event for feature selection and the popup info widow dojo.connect(theFeatureLayer,"onClick",function(evt){ //Listener event for feature selection and the popup info widow var query = new esri.tasks.Query(); query.geometry = pointToExtent(map,evt.mapPoint,15); var deferred = theFeatureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW); map.infoWindow.setFeatures([evt.graphic]); map.infoWindow.show(evt.mapPoint); });Lastly, create the function which will populate your template with the content you want: function setPopupContent(graphic) { attr = graphic.attributes; curState = attr.STATE; content = 'Create your content here'; //If The state clicked is ABC, append the special notation if (curState == "ABC") { content = content + "<br/><br/>(estimates based on State average)"; } return content; }Steve
for ( j = 0; j < newGeog.length; j++) { if (newGeog == "A" || newGeog == "B" || newGeog == "C") { resultContent = "<tr>" + indc + ": <td>${" + indv + ":formatNumber} (State average)</td></tr>"; } else { resultContent = "<tr>" + indc + ": <td>${" + indv + ":formatNumber}</td></tr>"; } }
