In my ArcObjects program, I need to check where a polygon feature (named f_A here) is included / overlapped with another polygon feature (named f_B hear). Is there an ArcObjects method for the this check-up? Thanks.
How to Execute Spatial Queries—ArcObjects 10.4 Help for Java | ArcGIS for Desktop . The article is for Java, but the concepts translate to .NET.
Hi Shaning,
This would be really easy with arcpy, but from what I can tell this article might help you out with how to use the Intersect tool with ArcObjects geoprocessing:
https://www.esri.com/news/arcuser/1207/files/gp_arcobjects.pdf
Or, the ITopologicalOperator.Intersect method could be used to determine if there is overlap.
Good luck!
Micah
Thanks a lot.
Here's how I determine if a polygon overlaps another polygon
pTopoOp <SPAN class="operator token">=</SPAN> pFeature<SPAN class="punctuation token">.</SPAN>Shape Dim pInGeometry As ESRI<SPAN class="punctuation token">.</SPAN>ArcGIS<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">.</SPAN>IGeometry5 pInGeometry <SPAN class="operator token">=</SPAN> pOtherFeature<SPAN class="punctuation token">.</SPAN>Shape If pInGeometry<SPAN class="punctuation token">.</SPAN>Dimension <SPAN class="operator token">=</SPAN> ESRI<SPAN class="punctuation token">.</SPAN>ArcGIS<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">.</SPAN>esriGeometryDimension<SPAN class="punctuation token">.</SPAN>esriGeometry2Dimension Then 'check <SPAN class="keyword token">if</SPAN> the feature <SPAN class="keyword token">is</SPAN> a polygon pOverlapGeometry <SPAN class="operator token">=</SPAN> pTopoOp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Intersect</SPAN><SPAN class="punctuation token">(</SPAN>pInGeometry<SPAN class="punctuation token">,</SPAN> ESRI<SPAN class="punctuation token">.</SPAN>ArcGIS<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">.</SPAN>esriGeometryDimension<SPAN class="punctuation token">.</SPAN>esriGeometry2Dimension<SPAN class="punctuation token">)</SPAN> If Not pOverlapGeometry Is Nothing And Not pOverlapGeometry<SPAN class="punctuation token">.</SPAN>IsEmpty Then <SPAN class="string token">'you'</SPAN>ve got an overlapping polygon End If End If<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Ken: Thanks for your code. Could you tell me what is the data type of pOverlapGeometry since I need to convert your VB into c#. Thanks.<BR />
It's an IGeometry5 object
