Private Shared m_aoInit As IAoInitialize ' ' You must initialize an ArcGIS License to test ArcObjects code ' 'Use ClassInitialize to run code before running the first test in the class <ClassInitialize()> Public Shared Sub MyClassInitialize(ByVal testContext As TestContext) ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop) m_aoInit = New AoInitialize m_aoInit.Initialize(esriLicenseProductCode.esriLicenseProductCodeArcInfo) End Sub 'Use ClassCleanup to run code after all tests in a class have run <ClassCleanup()> Public Shared Sub MyClassCleanup() m_aoInit.Shutdown() End Sub
How can I access a gdb in Unit Test method so I can get some testing feature classes to test spatial operations in my ArcObject extension project. I'm using VS 2010 with ArcGIS 10 on Window 7 machine to create a Desktop component.Right now I'm getting COMException from HRESULT: 0x80040258 when I call "workspaceFactory.OpenFromFile(path, 0)".Thanks!Julie
Alex,You are right. The license make me to be able to get the feature classes. But this line gave an error:public static void ClassCleanup() { fileGDB = null; m_aoInit.Shutdown(); //ERROR: COM object that has been separated from its underlying RCW cannot be used. }my m_aoInit was defined in ClassInitialize, just like yours.Vara,The Window 7 machine is 64 bit.Thanks for your help!Julie
private IGeoDataServer InitGeoDataServerFromWorkspace(IWorkspace geodatabase) { // Create the GeoDataServer and cast to the the IGeoDataServerInit interface. IGeoDataServer geoDataServer = new GeoDataServerClass(); IGeoDataServerInit geoDataServerInit = (IGeoDataServerInit)geoDataServer; // Initialize the GeoDataServer and return it. geoDataServerInit.InitWithWorkspace(geodatabase); return geoDataServer; }
[TestMethod()] //[DeploymentItem("Batch Reconcile and Post.exe")] public void InitGeoDataServerFromWorkspaceTest() { ArcSDEUtilities_Accessor target = new ArcSDEUtilities_Accessor(); IWorkspace geodatabase = (IWorkspace)iworkspacemock.MockInstance; IGeoDataServer expected = (IGeoDataServer)geodataservermock.MockInstance; IGeoDataServer actual; actual = target.InitGeoDataServerFromWorkspace(geodatabase); Assert.AreEqual(expected, actual); }
