When a user tries to click a line or point feature class nothing happens. Apparently the drawn symbol is offset if you look at the map below. Why is this happening and is it possible to fix it?
Hi Jordan, this could be related to a bug that a patch was released for version 10.6.1.
Here's a link to this patch for 10.6.1: Esri Support Portal for ArcGIS 10.6 (10.6.1)
I'm curious - we're seeing pretty much the exact same behavior, but in Portal 10.7.1 with WAB dev edition, v. 2.9.
Essentially when we click on a point that has multiple features present, and toggle through the pop-ups - the selection to reflect which pop-up is active is offset from the actual feature - point, line or polygon, doesn't matter - all show this behavior.
Have there been any other reports of this happening in 10.7.1?
This doesn't happen in the WebMap that's used in the App.
Thanks -
Allen
Hey Victoria,
We're using the Web AppBuilder for ArcGIS (not the dev edition) with Portal for ArcGIS v10.6.
Is this in ArcGIS Online or Portal for ArcGIS or are you using Web App Builder for Developers?
