infile=open(r'C:\Path\To\Input.csv','r') #opens a read only copy #get csv into array: lines=[] for line in infile: lines.append(line.split(',')) infile.close() toOut=[lines[0]] #start output with the header prevFC=lines[1][3] #start with first fc tempList=[] for line in lines[1:]: #skip header if line[0]=='\n' or line[0]=="(Newline)\n": continue fc=line[3] if prevFC!=fc: avg=sum(tempList)/float(len(tempList)) toOut.append(['','',str(avg),'\n']) toOut.append(['','','','\n']) #add blank line tempList=[] toOut.append(line) val=float(line[2]) tempList.append(val) prevFC=fc #add last average line: avg=sum(tempList)/float(len(tempList)) toOut.append(['','',str(avg),'\n']) toOut.append(['','','','\n']) #add blank line #build output: toOutCSV='' for line in toOut: toOutCSV+=','.join(line) #Write to output file: outfile=open(r'C:\Path\To\Output.csv','w') #opens a write copy (will overwrite output) outfile.write(toOutCSV) outfile.close()
with open("foo.csv", "r") as f: f.readline() # get rid of the first line # this section goes in a loop f.readline() #discard newline lineOne = f.readline() # first line with a value x = float(lineOne.split(",")[2]) lineTwo = f.readline() x += (float(lineTwo.split(",")[2]))/2 # this is your value # do something
