Ryan,Importing X-Y data directly from excel is often problematic because ArcMap scans the first 6 records to determine a data type and can get messed up between text and numbers. It is generally best to save the data in .csv format first, check the data and load from that. I copied your table into Notepad, deleted the space in one name and imported to excel then saved as csv and they plotted OK except that the Lat-Long coordinates for the volcanoes are quite a bit off: Pantelleria is showing up 40 km south of where it should be and the others are similarly out. You could probably just ADD a map from the Resource center (on the File menu) and make points in a feature class at the correct volcanoes.Hardolph
