where python echo %PYTHONHOME% echo %PATH% dir C:\Python27
Thanks Stuart,This helps a lot, and your explanation is very clear. I'm in the process of re-installing right now and will set the PATH and PYTHONHOME variables. I had installed the Enthought for python and had forgotten that I had it on my computer. Prior to uninstalling I had tried just changing the the PATH and PYTHONHOME variables, but that alone didn't end up doing the trick. If I'm understanding what you're saying correctly if I want to run 64bit python for scripts outside of ArcGIS I should simply be able to change the PATH and PYTHONHOME variables temporarily to point them to the 64 bit version?-Tom
