try: # Open an insert cursor for the new feature class # cur = arcpy.InsertCursor(fcname) # Create an array and point object needed to create features # lineArray = arcpy.Array() pnt = arcpy.Point() # Initialize a variable for keeping track of a feature's ID. # ID = -1 for line in coordList: # Open the input file # set the point's ID, X and Y properties # FeatID, pnt.ID, pnt.X, pnt.Y = string.split(line,",") print FeatID, pnt.ID, pnt.X, pnt.Y if ID == -1: ID = pnt.ID FeatID_load = FeatID # Add the point to the feature's array of points # If the ID has changed, create a new feature # #print ID, pnt.ID if ID != pnt.ID: # Create a new row or feature, in the feature class # feat = cur.newRow() feat.setValue("OW_ID", FeatID) # Set the geometry of the new feature to the array of points # feat.shape = lineArray # Insert the feature # cur.insertRow(feat) lineArray.removeAll() lineArray.add(pnt) ID = pnt.ID FeatID_load = FeatID # Add the last feature # feat = cur.newRow() feat.setValue("OW_ID", FeatID_load) feat.shape = lineArray cur.insertRow(feat) lineArray.removeAll() del cur except Exception as e: print e.message
try: # Open an insert cursor for the new feature class # cur = arcpy.InsertCursor(fcname) # Create an array and point object needed to create features # lineArray = arcpy.Array() pnt = arcpy.Point() # Initialize a variable for keeping track of a feature's ID. # ID = -1 for line in coordList: # Open the input file # set the point's ID, X and Y properties # pnt.ID, pnt.X, pnt.Y = string.split(line,",") #print pnt.ID, pnt.X, pnt.Y if ID == -1: ID = pnt.ID # Add the point to the feature's array of points # If the ID has changed, create a new feature # #print ID, pnt.ID if ID != pnt.ID: # Create a new row or feature, in the feature class # feat = cur.newRow() # Set the geometry of the new feature to the array of points # feat.shape = lineArray # Insert the feature # cur.insertRow(feat) lineArray.removeAll() lineArray.add(pnt) ID = pnt.ID # Add the last feature # feat = cur.newRow() feat.shape = lineArray cur.insertRow(feat) lineArray.removeAll() del cur except Exception as e: print e.message
try: # Open an insert cursor for the new feature class # cur = arcpy.InsertCursor(fcname) # Create an array and point object needed to create features # lineArray = arcpy.Array() pnt = arcpy.Point() # Initialize a variable for keeping track of a feature's ID. # ID = -1 for line in coordList: # Open the input file # set the point's ID, X and Y properties # FeatID, pnt.ID, pnt.X, pnt.Y = string.split(line,",") print FeatID, pnt.ID, pnt.X, pnt.Y if ID == -1: ID = pnt.ID # Add the point to the feature's array of points # If the ID has changed, create a new feature # #print ID, pnt.ID if ID != pnt.ID: # Create a new row or feature, in the feature class # feat = cur.newRow() feat.setValue("OW_ID", FeatID) # Set the geometry of the new feature to the array of points # feat.shape = lineArray # Insert the feature # cur.insertRow(feat) lineArray.removeAll() lineArray.add(pnt) ID = pnt.ID # Add the last feature # feat = cur.newRow() feat.setValue("OW_ID", FeatID) feat.shape = lineArray cur.insertRow(feat) lineArray.removeAll() del cur except Exception as e: print e.message
IDLE 2.6.5 >>> import arcpy >>> coordList = ['10953.36724322,20031.2536665', '10997.81733525,20052.4203769', '10993.08806586,20039.092436', '10948.63797384,20017.9257255', '10953.36724322,20031.2536665'] >>> array = arcpy.Array() >>> point = arcpy.Point() >>> featureList = [] >>> for each in coordList: XYpair = each.split(',') point.X = XYpair[0] point.Y = XYpair[1] featureList.append(point) array.add(point) >>> array.add(featureList[0]) >>> polygon = arcpy.Polygon(array) >>> arcpy.CopyFeatures_management(polygon, r'C:\testCopyPoly.shp') <Result 'C:\\testCopyPoly.shp'>
for each in coordList: XYpair = each.split(',') pnt.X = XYpair[0] pnt.Y = XYpair[1] # load pnt object into array, etc.
