Hi folks-I need help thinking something through. Basically what I'd like is to have a modified append tool that not only appends multiple the point attribute data, but also "pastes" the inputted shapefile's name(s) to a filename attribute column. That way I can track where the data came from. The only way I can think to do this is something along the lines of the following:for each shp in featureclasses:
outFeatureClass = os.path.join("C:\GIS\Scripts\temp\temptrks", shp.strip(".shp"))
arcpy.CopyFeatures_management(shp, outFeatureClass)
arcpy.AddField_management(outFeatureClass, "filename", "TEXT", "","", "254")
arcpy.CalculateField_management(outFeatureClass, "filename",
str(shp), "PYTHON")
Then I'd like to append it to a target dataset.What I'd like to do is be able to have a user drag and drop multiple shapefiles from multiple directories into a Multiple Value input box (like that in the Append tool).My questions are two:1) Is there an easier/better way?2) If not, to what do I set the parameter type (Multiple Value is not a selection).RK
