I am trying to link two map extents so that when Map1 extent changes, so does Map2... and vice-versa. I've been using the extent-change event for both Map1 and Map2, but get stuck in an cycle.When I pan Map1, the Map1 extent-change event is fired. This changes Map2 extent, which fires extentChange2 event, which changes Map1 extent... and the cycle continues. Any ideas? Here is the code for reference:Map1.on("extent-change", extentChange1);
Map2.on("extent-change", extentChange2);
function extentChange1(evt){
Map2.setExtent(evt.extent);
function extentChange2(evt){
Map1.setExtent(evt.extent);
