LocalMapService localMapServiceTactical = new LocalMapService() { Path = @C:\Data\tactical.mpk, EnableDynamicLayers = true }; // Start the local map service and once initialized localMapServiceTactical.StartAsync((mapService) => { // create a new local dynamic map service layer based on the local map service _arcGISLocalDynamicMapServiceLayer = new ArcGISLocalDynamicMapServiceLayer(localMapServiceTactical) { ID = "Tactical", ImageFormat = ArcGISDynamicMapServiceLayer.RestImageFormat.PNG32, }; // Set up an event handler for the layer initialized event _arcGISLocalDynamicMapServiceLayer.Initialized += (s, e) => { //Enable the UI once the layer has initialized //DynamicLayersUiGrid.IsEnabled = true; DataContext = this; //IsBusy = false; }; // Add the layer to the map _map.Layers.Add(_arcGISLocalDynamicMapServiceLayer); });
ArcGISLocalFeatureLayer arcGISLocalFeatureLayer = null; LocalFeatureService lfs = new LocalFeatureService(); lfs.Path = @C:\Data\tactical.mpk; arcGISLocalFeatureLayer = new ArcGISLocalFeatureLayer(lfs, "Target"); // Set the ID. arcGISLocalFeatureLayer.ID = "Target"; arcGISLocalFeatureLayer.Editable = true; arcGISLocalFeatureLayer.ValidateEdits = true; arcGISLocalFeatureLayer.AutoSave = true; arcGISLocalFeatureLayer.MouseLeftButtonUp += new GraphicsLayer.MouseButtonEventHandler(arcGISLocalFeatureLayer_MouseLeftButtonUp); // Define a SimpleRenderer with a SimpleMarkerSymbol to display each observation. Each observation // will be a small red triangle. ESRI.ArcGIS.Client.SimpleRenderer mySimpleRenderer2 = new ESRI.ArcGIS.Client.SimpleRenderer(); ESRI.ArcGIS.Client.Symbols.SimpleMarkerSymbol mySymbol2 = new ESRI.ArcGIS.Client.Symbols.SimpleMarkerSymbol(); System.Windows.Media.SolidColorBrush defaultBrush2 = new System.Windows.Media.SolidColorBrush(System.Windows.Media.Color.FromArgb(255, 255, 0, 0)); //Red mySymbol2.Color = defaultBrush2; mySymbol2.Size = 8; mySymbol2.Style = ESRI.ArcGIS.Client.Symbols.SimpleMarkerSymbol.SimpleMarkerStyle.Triangle; mySimpleRenderer2.Symbol = mySymbol2; arcGISLocalFeatureLayer.Renderer = mySimpleRenderer2; arcGISLocalFeatureLayer.InitializationFailed += new System.EventHandler<System.EventArgs>(arcGISLocalFeatureLayer_InitializationFailed); arcGISLocalFeatureLayer.Initialize(); // Add the local feature layer to the map. The map will handle the initialization of the layer. map.Layers.Add(arcGISLocalFeatureLayer); ESRI.ArcGIS.Client.Toolkit.EditorWidget editorWidget = null; this.editorWidget = new ESRI.ArcGIS.Client.Toolkit.EditorWidget(); this.editorWidget.Margin = new Thickness(12, 50, 0, 0); this.editorWidget.Map = map; this.editorWidget.AutoSelect = true; this.editorWidget.AlwaysDisplayDefaultTemplates = true; this.editorWidget.VerticalAlignment = System.Windows.VerticalAlignment.Top; this.editorWidget.HorizontalAlignment = System.Windows.HorizontalAlignment.Right; this.editorWidget.ShowAttributesOnAdd = true; this.editorWidget.Loaded += new RoutedEventHandler(editorWidget_Loaded); this.editorWidget.DataContext = arcGISLocalFeatureLayer; this.editorWidget.LayerIDs = layerIDs; this.editorWidget.ApplyTemplate(); LayoutRoot.Children.Add(editorWidget);
The editor widget has a Map property that you have to set. Have you done that?http://resources.arcgis.com/en/help/runtime-wpf/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Editor_members.html
ESRI.ArcGIS.Client.Toolkit.EditorWidget editorWidget = null; string[] layerIDs = { "Target" }; this.editorWidget = new ESRI.ArcGIS.Client.Toolkit.EditorWidget(); this.editorWidget.Margin = new Thickness(12, 50, 0, 0); this.editorWidget.Map = map; this.editorWidget.AutoSelect = true; this.editorWidget.AlwaysDisplayDefaultTemplates = true; this.editorWidget.VerticalAlignment = System.Windows.VerticalAlignment.Top; this.editorWidget.HorizontalAlignment = System.Windows.HorizontalAlignment.Right; this.editorWidget.ShowAttributesOnAdd = true; this.editorWidget.Loaded += new RoutedEventHandler(editorWidget_Loaded); this.editorWidget.DataContext = arcGISLocalFeatureLayer; this.editorWidget.LayerIDs = layerIDs; this.editorWidget.ApplyTemplate(); LayoutRoot.Children.Add(editorWidget);
