I'm not sure I completely understand your question but here are a few things I noticed: -you're using a map service in web mercator(wkid 102100) but specifying a geographic extent(wkid 4326). Use esri.geometry.geographicToWebMercator() to convert your extent before passing it to your map: var initialExtent = new esri.geometry.Extent({"xmin":-120.227821999585,"ymin":20.5332698820995,"xmax":-65.9816769016675,"ymax":71.4062353670687,"spatialReference":{"wkid":4326}}); map = new esri.Map("mapDiv", { extent: esri.geometry.geographicToWebMercator(initialExtent) }); -you're adding a tile map service but using the dynamic map service constructor. Use: var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); -to handle resizing of the browser use this: dojo.connect(map, 'onLoad', function() { // handle resize of the browser dojo.connect(dijit.byId('map'), 'resize', map,map.resize); //Listen for click event on the map, when the user clicks on the map call executeQueryTask function. dojo.connect(map, "onClick", executeQueryTask); }); Note: the map's onLoad event is also where you should connect your onClick handler Here's a tweaked version of your whole page: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>QueryTask with geometry, results as an InfoWindow</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> html, body {height: 100%; width: 100%; margin: 1; padding: 0;} body{background-color:#730; overflow:hidden; font-family: "Trebuchet MS"; border:5px solid black} #map{overflow:hidden; padding:0;} .AppTitle{font-size:3em; color: yellow;} .esriScalebar{height: 60%;} </style> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script> <script type="text/javascript" language="Javascript"> dojo.require("esri.map"); dojo.require("esri.tasks.query"); dojo.require("dojo.parser"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.dijit.Scalebar"); var map, queryTask, query; var symbol, infoTemplate; function init() { var initialExtent = new esri.geometry.Extent({"xmin":-120.227821999585,"ymin":20.5332698820995,"xmax":-65.9816769016675,"ymax":71.4062353670687,"spatialReference":{"wkid":4326}}); map = new esri.Map("mapDiv", { extent: esri.geometry.geographicToWebMercator(initialExtent) }); //create and add new layer var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); map.addLayer(layer); dojo.connect(map, 'onLoad', function() { // handle resize of the browser dojo.connect(dijit.byId('map'), 'resize', map,map.resize); dojo.connect(map, "onClick", executeQueryTask); }); //build query task queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"); query = new esri.tasks.Query(); query.returnGeometry = true; query.outFields = ["STATE_NAME", "STATE_ABBR", "SQMI", "MALES", "FEMALES"]; //create the infoTemplate to be used in the infoWindow. //All ${attributeName} will be substituted with the attribute value for current feature. infoTemplate = new esri.InfoTemplate("${STATE_NAME}", "Abbreviation: ${STATE_ABBR}<br />Square Miles: ${SQMI}<br /> # of Males: ${MALES}<br /> # of Females: ${FEMALES}"); symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.5])); } function executeQueryTask(evt) { query.geometry = evt.mapPoint; queryTask.execute(query, showResults); } function showResults(featureSet) { //remove all graphics on the maps graphics layer map.graphics.clear(); var features = featureSet.features; dojo.forEach(features,function(feature){ var graphic = feature; graphic.setSymbol(symbol); //Set the infoTemplate. graphic.setInfoTemplate(infoTemplate); //Add graphic to the map graphics layer. map.graphics.add(graphic); }); dojo.connect(map.graphics, "onMouseMove", function(evt) { var g = evt.graphic; map.infoWindow.setContent(g.getContent()); map.infoWindow.setTitle(g.getTitle()); map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)); }); dojo.connect(map.graphics, "onMouseOut", function() {map.infoWindow.hide();} ); } dojo.addOnLoad(init); </script> </head> <body class="claro"> Click on a state to get more info. When state is highlighted, move mouse over state to get more info. <div id="mapDiv" style="width:600px; height:600px; border:1px solid #000;"></div> </body> </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center"> </div> <div dojotype="dijit.layout.ContentPane" region="top" style="width: 100%; height: 20%;"> <div style="position: absolute; top: 60px; left:900px;"> <span class="AppTitle"> Newbie Test</span> </div> </div> </div> </body> </html>
