Hi all, I am trying to use JQuery and bootstrap in my application but cant seem to make it work. I get: "Error: MultipleDefine". Any idea why? jsbin is here.
Thanks,Alex
Alex,
The jquery scripts should to added before adding the esri scripts. That should take care of the myultileDefine
error. I am not able to look further as I dont have all the js files. Hope you should be able to take care of it.
<script src="https://code.jquery.com/jquery-1.11.3.min.js"></script>
<script src="https://code.jquery.com/ui/1.11.4/jquery-ui.min.js"></script>
<script src="http://js.arcgis.com/3.14/"></script>
regards,
Theju
Thanks! That was it.
On a related note, I recently ran into a scenario where I needed to use multiple versions of jQuery. If you ever run into this and experience issues, you can work around it by using noConflict:
https://api.jquery.com/jquery.noconflict/
Just thought I'd give this information in case anyone finds it helpful!
It indeed can be helpful thanks for sharing!
