I'm new to arcgis API for python. I can't figure out how to get a list of domain values from a hosted feature layer. I did read the api-reference, and can see that there is a query_domain method for the FeatureLayerCollection class (here: arcgis.features module — arcgis 1.8.2 documentation ) but I don't understand the syntax well enough to figure out how to actually write the code.
Thank you,
Jes
The best I could come up with is that you'll have to access the properties of the FL and loop through it to find coded values.
Here's a sample:
from arcgis import GIS gis = ("https://arcgis.com", "username", "password") #Get the arcgis item (this would be your hosted FGDB). item = gis.content.get("itemID") #Get the layers list from the item. layers = item.layers #Select the layer from the list you want to use. fl = layers[0] #Get the properties. properties = fl.properties
#Loop through the JSON to extract the coded values and save them to a list.
lst = []
for row in properties[fields]:
if row['domain']:
lst.append(row['domain'])
That should get you a list of the dictionaries associated with each coded domain into a neat list.
Thank you Kevin!
Your post was very helpful and set me on the right path. This is what I ended up doing, in case this is useful to others.
<SPAN class="keyword token">from</SPAN> arcgis <SPAN class="keyword token">import</SPAN> GIS <SPAN class="keyword token">def</SPAN> <SPAN class="token function">getDomainNames</SPAN><SPAN class="punctuation token">(</SPAN>itemID<SPAN class="punctuation token">,</SPAN> layerNumber<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""" Returns a set of domain names from a feature layer within a feature layer collection. :param itemID: identification number for an ArcOnline or Portal item (Feature Layer Collection or FGDB) :type itemID: str :param layerNumber: the integer [0 and up] that calls the feature layer of interest :type layerNumber: int """</SPAN> <SPAN class="comment token"># Assumes user is connected to their ArcOnline account in ArcPro.</SPAN> gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"pro"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Get the arcgis item (this would be your hosted FGDB).</SPAN> item <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>itemID<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Select the layer within the feature layer collection.</SPAN> fl <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># Get the properties.</SPAN> properties <SPAN class="operator token">=</SPAN> fl<SPAN class="punctuation token">.</SPAN>properties <SPAN class="comment token"># create an empty set</SPAN> nameSet <SPAN class="operator token">=</SPAN> set<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Loop through properties, get a list of all coded values for the given domain.</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> properties<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># if domain exists for the field and the domain type is codedValue:</SPAN> <SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'domain'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">and</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'domain'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'type'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">'codedValue'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># add the domain name to the set.</SPAN> nameSet<SPAN class="punctuation token">.</SPAN>add<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'domain'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>nameSet<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">getDomainValues</SPAN><SPAN class="punctuation token">(</SPAN>itemID<SPAN class="punctuation token">,</SPAN> layerNumber<SPAN class="punctuation token">,</SPAN> domName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""" Returns a list of domain codes from a specific domain within a feature layer. :param itemID: identification number for an ArcOnline or Portal item (Feature Layer Collection or FGDB) :type itemID: str :param layerNumber: the integer [0 and up] that calls the feature layer of interest :type layerNumber: int :param domName: name of the domain of interest """</SPAN> <SPAN class="comment token"># Assumes connected to duinc in ArcPro</SPAN> gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"pro"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#Get the arcgis item (this would be your hosted FGDB).</SPAN> item <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>itemID<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Select the layer within the feature layer collection.</SPAN> fl <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">[</SPAN>layerNumber<SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># Get the properties.</SPAN> properties <SPAN class="operator token">=</SPAN> fl<SPAN class="punctuation token">.</SPAN>properties <SPAN class="comment token"># Loop through properties, get a list of all coded value domains.</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> properties<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># if domain exists and the domain name is correct:</SPAN> <SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'domain'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">and</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'domain'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> domName<SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># create a list of all codes included in that domain</SPAN> valueList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'code'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'domain'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'codedValues'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>valueList<SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Edit: After tinkering with the query domains method for Feature Layer Collections, I found out that it wasn't working at all and submitted the issue to ESRI. I think it's an issue with the REST API.
