map.infoWindow.setFeatures([gmarkers[index]]); map.infoWindow.show(gmarkers[index].geometry);
map.infoWindow.hide(); map.infoWindow.resize(475,400); map.infoWindow.setTitle(title); map.infoWindow.setContent(tc.domNode); map.infoWindow.setFixedAnchor(esri.dijit.InfoWindow.ANCHOR_UPPERRIGHT); var maxPoint = new esri.geometry.Point(map.extent.xmax, map.extent.ymax); var centerPoint = new esri.geometry.Point(map.extent.getCenter()); var maxPointScreen = map.toScreen(maxPoint); var centerPointScreen = map.toScreen(centerPoint); var xDiff = Math.abs(maxPointScreen.x - evt.screenPoint.x) - 505; var yDiff = Math.abs(maxPointScreen.y - evt.screenPoint.y) - 485; if (xDiff < 0) {centerPointScreen.x -= xDiff;} if (yDiff < 0) {centerPointScreen.y += yDiff;} centerPoint = map.toMap(centerPointScreen); map.centerAt(centerPoint); map.infoWindow.show(evt.screenPoint, esri.dijit.InfoWindow.ANCHOR_UPPERRIGHT);
function reveal_site(i) { var split = i.split(','); var index = split[0]; var latitude = split[1]; var longitude = split[2]; if(index) { point = new esri.geometry.Point(longitude,latitude,new esri.SpatialReference({ wkid: 4326 })); point = esri.geometry.geographicToWebMercator(point); map.infoWindow.setTitle(gmarkers[index].getTitle()); map.infoWindow.setContent(gmarkers[index].getContent()); map.infoWindow.show(point, point); } }
function initializeCruises() { var content = ""; var count = 1; for (var j=0;j<dataLayer.graphics.length;j++) { graphic = dataLayer.graphics; var xPt = graphic.attributes.x; var yPt = graphic.attributes.y; var id = graphic.attributes.id; var region = graphic.attributes.region; var cruise = graphic.attributes.cruise; var dates = graphic.attributes.dates; content += "<li style='background-color: #0000ff;color: #ffffff;' onclick='showCruise("+id+");'onmouseover='highlightCruise("+xPt+","+yPt+");'onmouseout='highlightLayer.clear();'><b>"+(count)+")</b> "+region+" - Cruise "+cruise+"<br/>("+dates+")</li>"; count++; } dojo.byId("itemsList").innerHTML = content; } // highlights a cruise on the map from the listing in the right pane function highlightCruise(xPt,yPt) { var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 25, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 255, 0]), 3.5), new dojo.Color([0, 255, 0, 0.0])); var geometry = new esri.geometry.Point(xPt, yPt); geometry = esri.geometry.geographicToWebMercator(geometry); highlightLayer.add(new esri.Graphic(geometry, symbol)); }
