File geodatabase is an Esri storage format. It has nothing to do with Microsoft's SQL-Serverdatabase structure. They are incompatible, in the same way that diesel fuel can't be usedby a gasoline engine.- V
Jamal,The .gdb file (file geodatabase) cannot be directly converted to a .mdf file (SQL Server database file). Instead, create a new geodatabase on the database server, then import or copy and paste the data from the file geodatabase to the geodatabase on the database server.Regards,-Kim
