Hi All,
I've downloaded the codes for the TAB THEME (web app builder) and hosted it on our own server. By default, the table of content in the left pane is hidden and you have to click the arrow icon at the lower left corner to open it. How can I make the TOC expanded by default and display the info in the "ABOUT" widget? which script i need to modify?
PLEASE SEE ATTACHED SCREENSHOT
thanks,
Wilson
Wilson,
If you are using WAB 1.3 or greater than if you have one of the widgets that is inside the Tab controller set to preload/open at start, then the tab controller will automatically be maximized. Click the yellow dot to make it green.
THANK YOU SO MUCH!!! IT WORKS
