Quick question - when you call abortOperation() in an edit session -- you still have to stopEditing() afterward right? abortOperation is described as "canceling" an edit, I wasn't sure if stopEditing was necessary. Does what I have below look appropriate?
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
editor <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Editor<SPAN class="punctuation token">(</SPAN>db_con<SPAN class="punctuation token">)</SPAN>
editor<SPAN class="punctuation token">.</SPAN>startEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN>
editor<SPAN class="punctuation token">.</SPAN>startOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN>gpTestWriteFC<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'FirstName'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LastName'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> iCursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> item <SPAN class="keyword token">in</SPAN> insertList<SPAN class="punctuation token">:</SPAN>
iCursor<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN>
editor<SPAN class="punctuation token">.</SPAN>stopOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
editor<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> editor<SPAN class="punctuation token">.</SPAN>isEditing <SPAN class="operator token">==</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">:</SPAN>
editor<SPAN class="punctuation token">.</SPAN>abortOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
editor<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN>
fullError <SPAN class="operator token">=</SPAN> traceback<SPAN class="punctuation token">.</SPAN>format_exc<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN>fullError<SPAN class="punctuation token">)</SPAN>
sys<SPAN class="punctuation token">.</SPAN>exit<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
