I have a dll in VB, where do I get access to AppRot (ArcGis 10):Dim pAppRoot As AppROTSet pAppRoot = New AppROTNow when I call the DLL from VBA, it works great.If I call the DLL from a separate application for C + +, then pAppRot is Nothing. In Previous versions Of ArcGis everything is working fine. How can I fix it?
If m_appROT.Count > 0 Then For q = 0 To m_appROT.Count - 1 'If TypeOf m_appROT.Item(i) Is IGxApplication Then ' ArcCatalog running If TypeOf m_appROT.Item(q) Is IMxApplication Then ' ArcMap running If m_appROT.Item(q).Visible = True Then If m_appROT.Item(q).Document.Title = lblConnectedTo.Text Then pApp = m_appROT.Item(q) ' The session originally used. End If End If End If Next q End If
Do you have a Count?pAppRoot.count is?I usually do this:If m_appROT.Count > 0 Then For q = 0 To m_appROT.Count - 1 'If TypeOf m_appROT.Item(i) Is IGxApplication Then ' ArcCatalog running If TypeOf m_appROT.Item(q) Is IMxApplication Then ' ArcMap running If m_appROT.Item(q).Visible = True Then If m_appROT.Item(q).Document.Title = lblConnectedTo.Text Then pApp = m_appROT.Item(q) ' The session originally used. End If End If End If Next q End If
