Hello All,
Does anyone know of a way I can take a large set of points (1 million plus) and create some sort of boundary or service area out of them?
I know this can be done manually but I would like to find an automated solution.
Hi Cody,
Take a look at the Minimum Bounding Geometry tool.
Hi Jake, Thanks for the reply.
I was looking for something that creates a little bit tighter of a polygon (not as square).
The more i research, the more i am starting to believe that only way i can get the result i want is to hand draw the service area.
Is the 'Convex Hull' option not what you are looking for?
Are your points numbered or sorted in any meaningful way in your attribute table?
The only meaningful sort could be an Account # or Grid #. They have a UID and other unique identifiers but nothing sequenced.
any which way you do this it's going to be "a cat out of a bag" sort of solution
None of these suggestions are perfect but it could be in the form of:
