This example: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/sandbox.html?sample=layers-featurelayer-collection returns a URL in the popup for each mapped point, but the URL is encoded incorrectly from the returned JSON. I'm at a loss on how to correctly encode the URL - help?
The link in the popup of the sample uses the Esri server as home location, so the complete link will never work. You'l need to take the last part of the popup link e.g. http%3A%2F%2Fearthquake.usgs.gov%2Fearthquakes%2Feventpage%2Fak13139479 and run the standard JS decodeURIComponent function on it.
decodeURIComponent("http%3A%2F%2Fearthquake.usgs.gov%2Fearthquakes%2Feventpage%2Fak13139479"); // returns "http://earthquake.usgs.gov/earthquakes/eventpage/ak13139479"
Thanks for pointing out this issue. We'll fix the sample. Another option is to display a table of fields using fieldInfos like this:
var pTemplate = { title: "{title}", content: [{ type: "fields", fieldInfos: [{ fieldName: "place", label: "Location", visible: true }, { fieldName: "time", label: "Date and time", visible: true }, { fieldName: "mag", label: "Magnitude", visible: true }, { fieldName: "mmi", label: "Intensity", visible: true }, { fieldName: "depth", label: "Depth", visible: true }, { fieldName: "felt", label: "Number who felt the quake", visible: true, format: { digitSeparator: true, places: 0 } }, { fieldName: "sig", label: "Significance", visible: true }, { fieldName: "url", label: "More info", visible: true }] }], fieldInfos: [{ fieldName: "time", format: { dateFormat: "short-date-short-time" } }] };
Then the link will be clickable in the table:
Thanks - I just found that removing the single quotes from the href=' in the also works - the URL in my JSON was returned the same way that the USGS url is returned (as a normal URL pointing to an outside location) - thanks for fixing the sample, and for the suggestion.
-Doug
