I am adding a markers layer called `layer1` like this to map
function drawPoints(mapInfo) {
layer1 = new esri.layers.GraphicsLayer();
for (var i = 0; i < mapInfo.length; i++) {
var projects = mapInfo;
var project = new esri.geometry.Point(projects.Longitude, projects.Latitude);
project = esri.geometry.geographicToWebMercator(project);
var symbol = new esri.symbol.PictureMarkerSymbol("img/map/marker.png", 18, 18);
projectInfoTemplate = new InfoTemplate();
projectInfoTemplate.setTitle("Project Details");
projectInfoTemplate.setContent('<div class="row"></div> ');
var projectsG = new esri.Graphic(project, symbol).setInfoTemplate(projectInfoTemplate);
layer1.add(projectsG);
map.addLayer(layer1);
}now in next request I need to clear map so I used the
map.removeLayer(layer1);
but this is causing error because the `layer1` still not created at first request. Now I need to check `IF` the map has a layer called `layer1` then removeit. Here is a pseudo code of what I need to do:
if(map.has/contains/include(layer1){
}can you please let me know how to do that?
