Dan..Thanks for your response.. Here is the ouput on sample data using approach-2 (Frequency):FID Shape Id NEAR_FID NEAR_DIST ConID Rowid FID FREQUENCY NEAR_DIST *0 Polygon 0 2 1716.566324 1 4 0 1 1716.5663241 Polygon 0 4 1656.804153 1 3 0 1 1656.8041532 Polygon 0 4 551.543298 2 1 0 2 551.5432983 Polygon 0 4 602.992525 1 2 0 1 602.9925254 Polygon 0 2 551.543298 2 1 0 2 551.543298I will post the out put from approach-1 in a second.Any comments on the above output??Thanks!\ABDALLA
Here is the output using the Dissolve tool to group features:FID Shape * NEAR_DIST ORIG_FID0 Polygon 551.543298 01 Polygon 551.543298 02 Polygon 602.992525 13 Polygon 1656.804153 24 Polygon 1716.566324 3
Dan..When I calculated the ConID by the Rowid , I got the same value numbers as Rowid..Is that what you think is right? look at the output below:FID Shape Id NEAR_FID NEAR_DIST ConID Rowid FID FREQUENCY NEAR_DIST *0 Polygon 0 2 1716.566324 4 4 0 1 1716.5663241 Polygon 0 4 1656.804153 3 3 0 1 1656.8041532 Polygon 0 4 551.543298 1 1 0 2 551.5432983 Polygon 0 4 602.992525 2 2 0 1 602.9925254 Polygon 0 2 551.543298 1 1 0 2 551.543298Do you think that would be a duplicate??Thanks a lot..ABDALLA
