IPolygon pg = MyFeature.Shape as IPolygon; if (pg.SpatialReference is IProjectedCoordinateSystem) { projCoordinateSystem = pg.SpatialReference as IProjectedCoordinateSystem; pg.Project(projCoordinateSystem.GeographicCoordinateSystem); // Update the DD textboxes. IArea area = pg as IArea; obj.set_Value(gpslatitude, string.Format("{0:0.######}", area.Centroid.Y)); obj.set_Value(gpslongitude, string.Format("{0:0.######}", area.Centroid.X)); }
If the geometry has a projected coordinate system then you should be able to just use the geographic coordinate system it's based on and project it. The following is a code snippet from one of our apps. ' Project the UTM to Lat/Long. Dim projCoordinateSystem As IProjectedCoordinateSystem = DirectCast(point.SpatialReference, IProjectedCoordinateSystem) point.Project(projCoordinateSystem.GeographicCoordinateSystem) ' Update the DD textboxes. DdLatitudeTextbox.Text = Format(point.Y, "0.000000") DdLongitudeTextbox.Text = Format(point.X, "0.000000")
