Hello!I searched for my problem in the forum and found some threads about the same problem but those couldn't help me solving my problem.I've installed Oracle and ArcSDE on the same machine (Red Hat Linux Server 64bit - Tikanga 5.4). When starting the prerequisite check I get the following error:Checking ST_GEOMETRY configuration setup... Current instance is not correctly setup for ST_GEOMETRY configuration. Unable to determine current version of ST_SHAPELIB. The latest ST_GEOMETRY and dependent libraries need to be copied to the correct software location. Checking ST_RASTER configuration setup... Current instance is not correctly setup for ST_RASTER configuration.
Although I've configured the listener.ora and tnsnames.ora and restarted the listener I get the "error".Listener.ora:LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = atem-db)(PORT=1521)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) ) SID_LIST_LISTENER= (SID_LIST= (SID_DESC= (GLOBAL_DBNAME=atem.atem.fuez) (ORACLE_HOME=/opt/oracle/11gR1/product/11.1.0/db_2) (SID_NAME=atem) (PROGRAM=extproc) (ENVS="EXTPROC_DLLS=/opt/arcsde/sdeexe100/lib/libst_shapelib.so:/opt/arcsde/sdeexe100/lib/libst_raster_ora.so") ) )
Tnsnames.ora:ATEM = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST=atem-db)(PORT=1521) (ADDRESS = (PROTOCOL = IPC)(Key = EXTPROC1521) ) (CONNECT_DATA = (SERVICE_NAME = atem) (SID = atem) (PRESENTATION = RO) ) )
Can anybody give me an advice?Thanks!
