Hello,I work on a project that involves the use of a total station to make high resolution topographic maps of streams for salmon habitat studies. We encountered this same problem with georeferencing the survey data. The problem is due to the higher accuracy of the total station compared to the accuracy of the gps coordinates collected for the control points. When you try to "lock on" to all of the control points, you end up distorting the survey data.To solve this problem, we developed an Add-In that our field crews use to project total station survey data in to a real-world coordinate system:http://ctt.joewheaton.org/homeI hope this helps!
Georeferencing does stretch and rotate the image when adding control points. It sounds like your control points are not very well spaces across your image and are focused in one area. It is best to space them out in each of the corners.Fundamentals for georeferencing a raster dataset: "If possible, you should spread the links over the entire raster dataset rather than concentrating them in one area. Typically, having at least one link near each corner of the raster dataset and a few throughout the interior produces the best results."
kmwhiteheadHello,I work on a project that involves the use of a total station to make high resolution topographic maps of streams for salmon habitat studies. We encountered this same problem with georeferencing the survey data. The problem is due to the higher accuracy of the total station compared to the accuracy of the gps coordinates collected for the control points. When you try to "lock on" to all of the control points, you end up distorting the survey data.To solve this problem, we developed an Add-In that our field crews use to project total station survey data in to a real-world coordinate system:http://ctt.joewheaton.org/homeI hope this helps!
