I'm writing a c# application using the ArcGIS 10.2.6 Runtime SDK for .Net. I'm trying to figure out a way to utilize a basemap that is using Gall's Stereographic projection. Can this be done? If so, can I get an offline version?
Could you provide a small sample to show what you're doing in your application? I tested these coordinate systems on my end and everything appears to be working fine.
World Imagery (3857)
http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer
World Street Map (3857)
http://services.arcgisonline.com/arcgis/rest/services/World_Street_Map/MapServer
World Topo Map (3857)
http://services.arcgisonline.com/arcgis/rest/services/World_Topo_Map/MapServer
Esri Imagery World 2D (4326) ** Extended Support **
http://services.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer
Esri StreetMap World 2D (4326) ** Extended Support **
http://services.arcgisonline.com/arcgis/rest/services/ESRI_StreetMap_World_2D/MapServer
** Code I used to test **
XAML
<Window x:Class="GallMap.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013" Title="Gall Stereographic Map" Height="350" Width="800"> <Grid> <Grid.Resources> <Style TargetType="{x:Type Border}"> <Setter Property="Margin" Value="10" /> <Setter Property="Padding" Value="5" /> <Setter Property="Background" Value="White" /> <Setter Property="BorderBrush" Value="Black" /> <Setter Property="BorderThickness" Value="2" /> </Style> <Style TargetType="{x:Type TextBlock}"> <Setter Property="FontSize" Value="20" /> <Setter Property="FontWeight" Value="Bold" /> <Setter Property="Background" Value="White" /> <Setter Property="Foreground" Value="Black" /> <Setter Property="TextAlignment" Value="Center"/> </Style> </Grid.Resources> <Grid.ColumnDefinitions> <ColumnDefinition /> <ColumnDefinition /> </Grid.ColumnDefinitions> <esri:MapView x:Name="MyMapView1" Margin="3" /> <esri:MapView x:Name="MyMapView2" Grid.Column="1" Margin="3"/> <Border VerticalAlignment="Bottom" HorizontalAlignment="Center" Grid.ColumnSpan="2"> <Border.Effect> <DropShadowEffect /> </Border.Effect> <StackPanel Orientation="Horizontal"> <StackPanel.Resources> <Style TargetType="{x:Type RadioButton}"> <Setter Property="Margin" Value="4,0,4,0" /> </Style> </StackPanel.Resources> <RadioButton Content="World Imagery" Checked="ToggleButton_OnChecked"/> <RadioButton Content="World Street" Checked="ToggleButton_OnChecked" /> <RadioButton Content="World Topo" Checked="ToggleButton_OnChecked" IsChecked="True" /> <RadioButton Content="World Imagery 2D" Checked="ToggleButton_OnChecked" /> <RadioButton Content="World Street 2D" Checked="ToggleButton_OnChecked" /> </StackPanel> </Border> <Border HorizontalAlignment="Left" VerticalAlignment="Top"> <Border.Effect> <DropShadowEffect /> </Border.Effect> <TextBlock Text="{Binding ElementName=MyMapView1, Path=SpatialReference.Wkid, StringFormat=Map WKID: {0}}" Padding="5" /> </Border> <Border HorizontalAlignment="Left" VerticalAlignment="Top" Grid.Column="1"> <Border.Effect> <DropShadowEffect /> </Border.Effect> <TextBlock Text="{Binding ElementName=MyMapView2, Path=SpatialReference.Wkid, StringFormat=Map WKID: {0}}" Padding="5" /> </Border> </Grid> </Window>
XAML.cs
using Esri.ArcGISRuntime.Controls; using Esri.ArcGISRuntime.Geometry; using Esri.ArcGISRuntime.Layers; using System; using System.Collections.Generic; using System.Windows; using System.Windows.Controls; namespace GallMap { public partial class MainWindow : Window { private readonly Dictionary<string, string> m_urls = new Dictionary<string, string> { {"World Imagery", "http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer"}, {"World Topo", "http://services.arcgisonline.com/arcgis/rest/services/World_Topo_Map/MapServer"}, {"World Street", "http://services.arcgisonline.com/arcgis/rest/services/World_Street_Map/MapServer"}, {"World Imagery 2D", "http://services.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer"}, {"World Street 2D", "http://services.arcgisonline.com/arcgis/rest/services/ESRI_StreetMap_World_2D/MapServer"} }; public MainWindow() { InitializeComponent(); } private void ToggleButton_OnChecked(object sender, RoutedEventArgs e) { var tag = (sender as RadioButton).Content.ToString(); var mapviews = new[] {MyMapView1, MyMapView2}; foreach (var mapview in mapviews) { var layer = new ArcGISDynamicMapServiceLayer(new Uri(m_urls[tag])); var wkid = Array.IndexOf(mapviews, mapview) == 0 ? 53016 : 54016; var map = new Map { SpatialReference = SpatialReference.Create(wkid), InitialViewpoint = new Viewpoint(new Envelope(-141, 7, -51, 78, SpatialReference.Create(4326))) }; map.Layers.Add(layer); mapview.Map = map; } } } }
Are you having problems using a layer with this particular projection? I can see two Gall Stereographic projections listed in the list of supported coordinate systems for runtime. Are you using either of these?
53016 : Sphere_Gall_Stereographic
54016 : World_Gall_Stereographic
Projected Coordinate Systems
https://developers.arcgis.com/net/desktop/guide/projected-coordinate-systems.htm
Sorry for being a noob to ArcGIS. Maybe I'm getting confused between Spatial Reference and Projections. Let me experiment with it. Thanks for the suggestion.
I'm only able to get 54016 : World_Gall_Stereographic to work with the deprecated services, such as ESRI_StreetMap_World_2D. Is there another map that can be used to represent this correctly?
Thank you so much for the detailed explanation. It is greatly appreciated. I am able to get the map to work when connected to the internet now. The issue is trying to use them offline. I'm confused on how to get a .tpk file of the maps for offline use. I downloaded the standard topology.tpk file that came with the sample package, but I cannot make it look like the Gall's Stereographic Maps.
