[Bindable] private var customcontent:String ='This is line one.\nThis is line two.'; [Bindable] private var customTextElems:Object; private function init():void{ customTextElems = new Object; customTextElems.myCustomTextElement = customcontent; this.printParameters.layoutOptions.customTextElements = customTextElems; printTask.getServiceInfo(); } <esri:PrintParameters id="printParameters" format="PDF" layoutTemplate="MyCustomTemplate" <esri:layoutOptions> <esri:LayoutOptions author="Author: ArcGIS for Flex Team" copyright="Copyright: © ArcGIS for Server" title="My Map"> </esri:LayoutOptions> </esri:layoutOptions> </esri:PrintParameters>
<esri:PrintParameters id="printParameters" format="PDF" layoutTemplate="MyCustomTemplate" map="{map}" > <esri:layoutOptions>[INDENT]<esri:LayoutOptions author="Author: ArcGIS for Flex Team" [/INDENT] [INDENT] copyright="Copyright: © ArcGIS for Server" [/INDENT] [INDENT] title="My Map"> [/INDENT] [INDENT=2]<esri:customTextElements> [/INDENT] [INDENT=3]<fx:Object> [/INDENT] [INDENT=4]<fx:myCustomTextElement> [/INDENT] [INDENT=5]<fx:String id="actualText">{customcontent}</fx:String> (error raised �??Data binding expression not allowed here�?�) [/INDENT] [INDENT=4]</fx:myCustomTextElement> [/INDENT] [INDENT=3]</fx:Object> [/INDENT] [INDENT=2]</esri:customTextElements> [/INDENT] [INDENT]</esri:LayoutOptions> [/INDENT] </esri:layoutOptions> </esri:PrintParameters>
You can also create the object like this:<fx:Object myCustomTextElement="{customcontent}"/>
What about customTextElements ?
Finally I had to come back on this one and I've got it working :
In client side (javascript) :
printTemplate.format = MapConfig.printService.format;
printTemplate.layout = PrWidget.mapTemplatesFilteringSelect.get('displayedValue');
printTemplate.preserveScale = false;
printTemplate.layoutOptions = {
titleText:PrWidget.titleTextBox.get("value"),
customTextElements:[
{Entite:PrWidget.entiteTextBox.get("value")},
{Rue:PrWidget.rueTextBox.get("value")},
{CodePostal:PrWidget.codepostalTextBox.get("value")},
{Ville:PrWidget.villeTextBox.get("value")},
{Contact:PrWidget.contactTextBox.get("value")},
{Mail:PrWidget.mailTextBox.get("value")},
{Telephone:PrWidget.telephoneTextBox.get("value")},
{Fax:PrWidget.faxTextBox.get("value")}
It will automatically search for text elements in the mxd template base on textElement elementName that matches the keys (if I've got a textElement which elementName in "Entite" in my mxd, then it will update it with the value I defined).
This prevent to add "extraParameters" just for updating text in the template.
