Has this Print utility issue been resolved with the map viewer? It appears printing from a web app utilizes the Print service just fine but printing from the map viewer only brings up the ESRI default. Will this be addressed soon?
Did you find a solution for setting the print service in ArcGIS Online. I continue to receive an error saying that "The print service URL you have entered is invalid or inaccessible." The print service is accessible, but AGOL continues to give an error.
Sorry Brian but we never found a solution. At that time we were exploring ArcGIS Online and I was curious about that feature. Since then we have completed projects that use Print Services from our ArcGIS servers but the clients have all been applications that we developed.
Hi Brian,
Can you share your print service URL? Is it internal or external? What browser are you using to input the print URL.
The error message indicates that ArcGIS Online couldn't access the URL, or the URL was not identified as a printing service. Is SSL Only enabled on your organization or Server?
Feel free to reply to these questions, or contact Esri Technical Support as they can help to discover what the specific issue is.
-Kelly
Kelly, I found out that my issue was related to me setting my print service up to run asynchronously. Once I set it to run synchronously it worked as expected. Thanks for replying!
