Under your Service you created on ARCGIS Server there is a spot that you can change the maximum number of records returned by the server. I think the default is like 1500. If you change this to the be greater than your number of records you can get everything back. Of course there is going to some delay before the autocomplete loads. Below is a picture on where you can find this setting.[ATTACH=CONFIG]12095[/ATTACH]Hope this help you in your problem.
If you follow the directions in the readme file, the autocompletesearch seems to work just fine in 3.0 final.You get a bunch of "no type declaration" warnings in the Flashcommander as component, but it doesn't seem to affect it as it works just fine.R_
Hi,If this widget is affected by the maximum number of records returned by server, what is limitation of the number of records? As I am not seeing all of my results in the drop down. Thanks for any positive reply.
Hi PhillipThe thing about not seeing what you are typeing into the searchbox, is a problem i don't understand, have you tried my testsite ?? I'll look at the thing about ignore Null values and a clearbutton - thanks for the ideas....Hi Xander - yes the widget is affected by the max. number in the service - and i can see that i have only told about this on the arcgis.com site, not in the info.txt file in the zip-file, sorry - i'll correct this soon - thanks.
MadsNice. Works very well. Very configurable as well! To improve the widget it would be nice to have it ignore null values in a table....and also to be able to see the letters you type into the search box. With those two additions it would be absolutely perfect for me!Again - good job!- and perhaps also a clear graphics button...
