Hello, I've scoured the internet in search of an ArcPy function that will perform the same function as the export button in the metadata ribbon in ArcGIS pro. I've found arcpy.ExportMetadata_Conversion(), which doesn't appear to be supported with ArcGIS Pro and Python 3. I've also found arcpy.ExportXMLWorkspaceDocument() (using the "SCHEMA_ONLY" parameter) but the XML file that is generated is not formatted correctly. Is there a more basic function that will have the same results as the built-in ArcGIS Pro tool?
