This is how it looks like in a JSBin.
Take a look at this thread where the original poster had a question on his map that showed features using a dropdown list of choices.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Display Find Task results in Dojo DataGrid</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/claroGrid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> require([ "esri/map", "esri/tasks/FindTask", "esri/tasks/FindParameters", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/Color", "dojo/on", "dojo/dom", "dijit/registry", "dojo/_base/array", "dojo/_base/connect", "dojox/grid/DataGrid", "dojo/data/ItemFileReadStore", "dijit/form/Button", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser ) { var findTask, findParams; var map, center, zoom; var grid, store; parser.parse(); registry.byId("search").on("click", doFind); center = [-83.266, 42.568]; zoom = 11; map = new esri.Map("map", { basemap: "streets", center: center, zoom: zoom }); //Create Find Task using the URL of the map service to search findTask = new FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/"); map.on("load", function () { //Create the find parameters findParams = new FindParameters(); findParams.returnGeometry = true; findParams.layerIds = [0]; findParams.searchFields = ["OWNERNME1", "OWNERNME2"]; findParams.outSpatialReference = map.spatialReference; console.log("find sr: ", findParams.outSpatialReference); }); function doFind() { //Set the search text to the value in the box findParams.searchText = dom.byId("ownerName").value; findTask.execute(findParams, showResults); } function showResults(results) { //This function works with an array of FindResult that the task returns map.graphics.clear(); var symbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2), new Color([98, 194, 204, 0.5]) ); //create array of attributes var items = arrayUtils.map(results, function (result) { var graphic = result.feature; graphic.setSymbol(symbol); map.graphics.add(graphic); return result.feature.attributes; }); //Create data object to be used in store var data = { identifier : "PARCELID", //This field needs to have unique values label : "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere. items : items }; //Create data store and bind to grid. store = new ItemFileReadStore({ data : data }); var grid = registry.byId("grid"); grid.setStore(store); grid.on("rowclick", onRowClickHandler); //Zoom back to the initial map extent map.centerAndZoom(center, zoom); } //Zoom to the parcel when the user clicks a row function onRowClickHandler(evt) { var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).PARCELID; var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) { return ((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId); }); if ( selectedTaxLot.length ) { map.setExtent(selectedTaxLot[0].geometry.getExtent(), true); } } }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;"> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="height:40px;"> <p>Owner name: <input type="text" id="ownerName" size="10" value="Katz" /> </p> <p> Year Built: <input type="text" id="txtYearBuilt" size="10" value=">1955" /> </p> <p>Residence Type: <input type="text" id="txtResType" size="30" value="'Colonial/2Sty'" /> </p> <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search </button> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;"> <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'"> <thead> <tr> <th field="PARCELID">Parcel ID</th> <th field="OWNERNME1" >Owner 1</th> <th field="OWNERNME2">Owner 2</th> <th field="RESYRBLT ">Year Built</th> <th field="RESSTRTYP ">Res Type</th> <th field="SITEADDRESS" width="100%">Address</th> </tr> </thead> </table> </div> </div> </body> </html>
