# ...snip # get all intersections ACDEFGHIJKM (see help diagrams for letters) arcpy.management.SelectLayerByLocation(fcLayer,'INTERSECT',gaLayer,selection_type='NEW_SELECTION') # copy to a temp layer, snap, then remove those outside but touching snapFC = prefix+fcAbbrev+"_snap" arcpy.management.CopyFeatures(fcLayer,snapFC) arcpy.management.MakeFeatureLayer(snapFC,touchLayer) # Have no selection to start arcpy.management.SelectLayerByLocation(gaLayer,'INTERSECT',fcLayer,selection_type='ADD_TO_SELECTION') arcpy.edit.Snap(touchLayer,[[gaLayer,'VERTEX',4],[gaLayer,'EDGE',4]]) # get outside touching to exclude DIJ (help diagram cases) arcpy.management.SelectLayerByLocation(touchLayer,'BOUNDARY_TOUCHES',gaLayer,selection_type='NEW_SELECTION') arcpy.management.SelectLayerByLocation(touchLayer,'WITHIN',gaLayer,selection_type='REMOVE_FROM_SELECTION') arcpy.management.SelectLayerByLocation(touchLayer,'CONTAINS',gaLayer,selection_type='REMOVE_FROM_SELECTION') # subtract outside touching if any DIJ (see help) cTouch = int(arcpy.management.GetCount(touchLayer).getOutput(0)) if cTouch == 0: arcpy.analysis.SpatialJoin(fcLayer,gaLayer, prefix+fcAbbrev,'JOIN_ONE_TO_MANY','KEEP_COMMON',"#",'INTERSECT') count = int(arcpy.management.GetCount(prefix+fcAbbrev).getOutput(0)) if count > 0: dCount[fcAbbrev] = count msg = "GA %s %s %s %d" % (aggregate_area,arcpy.management.GetCount(gaLayer),fcAbbrev,dCount[fcAbbrev]) logging.info(msg) print msg else: arcpy.management.Delete(prefix+fcAbbrev) else: lstPar = [row.par_id for row in arcpy.SearchCursor(touchLayer)] if len(lstPar) > 0: if len(lstPar) == 1: expr = "PAR_ID = "+str(lstPar[0]) else: expr = "PAR_ID in "+str(tuple(lstPar)) # print "touching outside",cTouch #,expr # remove from list of new parcels of interest try: arcpy.management.SelectLayerByAttribute(fcLayer,"REMOVE_FROM_SELECTION",expr) except: print "error",expr # if int(arcpy.management.GetCount(fcLayer).getOutput(0)) > 0: arcpy.analysis.SpatialJoin(fcLayer,gaLayer, prefix+fcAbbrev,'JOIN_ONE_TO_MANY','KEEP_COMMON',"#",'INTERSECT') count = int(arcpy.management.GetCount(prefix+fcAbbrev).getOutput(0)) if count > 0: dCount[fcAbbrev] = count # tag touched GA layers arcpy.management.SelectLayerByLocation(gaLayer,'INTERSECT',fcLayer,selection_type='ADD_TO_SELECTION') msg = "GA %s %s %s %d" % (aggregate_area,arcpy.management.GetCount(gaLayer),fcAbbrev,dCount[fcAbbrev]) logging.info(msg) print msg else: arcpy.management.Delete(prefix+fcAbbrev)
