Thank you so much!! It's working now. I had to add a few references (i.e. system.ServiceModel.Syndication)Edit:I was able to publish the map onto my server, and everything looks fantastic! Except for one item: I can't get the feed for some reason....When I tried to fetch a feed within my published map, nothing happens or I receive the error message. On the other hand, when I used the same feed (http://earthquake.usgs.gov/eqcenter/catalogs/eqs7day-M2.5.xml) or a different feed within the sample map (http://help.arcgis.com/EN/webapi/silverlight/samples/start.htm#GeoRSS), it was able to fetch the feed.I'm not sure what's wrong with my code? I was able to debug and publish my map. Here's my code:using System;using System.Collections.Generic;using System.IO;using System.Linq;using System.Net;using System.ServiceModel.Syndication;using System.Windows;using System.Windows.Controls;using System.Windows.Threading;using System.Xml;using System.Xml.Linq;using ESRI.ArcGIS.Client;using ESRI.ArcGIS.Client.Geometry;namespace M4{ public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); } private void Fetch_Click(object sender, RoutedEventArgs e) { if (FeedLocationTextBox.Text != String.Empty) { LoadRSS(FeedLocationTextBox.Text.Trim()); DispatcherTimer UpdateTimer = new System.Windows.Threading.DispatcherTimer(); UpdateTimer.Interval = new TimeSpan(0, 0, 0, 0, 60000); UpdateTimer.Tick += (evtsender, args) => { LoadRSS(FeedLocationTextBox.Text.Trim()); }; UpdateTimer.Start(); } } protected void LoadRSS(string uri) { WebClient wc = new WebClient(); wc.OpenReadCompleted += wc_OpenReadCompleted; Uri feedUri = new Uri(uri, UriKind.Absolute); wc.OpenReadAsync(feedUri); } private void wc_OpenReadCompleted(object sender, OpenReadCompletedEventArgs e) { if (e.Error != null) { FeedLocationTextBox.Text = "Error in Reading Feed. Try Again later!!"; return; } // Optional, use LINQ to query GeoRSS feed. //UseLinq(e.Result); return; using (Stream s = e.Result) { SyndicationFeed feed; List<SyndicationItem> feedItems = new List<SyndicationItem>(); GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; graphicsLayer.ClearGraphics(); using (XmlReader reader = XmlReader.Create(s)) { feed = SyndicationFeed.Load(reader); foreach (SyndicationItem feedItem in feed.Items) { SyndicationElementExtensionCollection ec = feedItem.ElementExtensions; string x = ""; string y = ""; string magnitude = feedItem.Title.Text; foreach (SyndicationElementExtension ee in ec) { XmlReader xr = ee.GetReader(); switch (ee.OuterName) { case ("lat"): { y = xr.ReadElementContentAsString(); break; } case ("long"): { x = xr.ReadElementContentAsString(); break; } } } if (!string.IsNullOrEmpty(x)) { Graphic graphic = new Graphic() { Geometry = new MapPoint(Convert.ToDouble(x, System.Globalization.CultureInfo.InvariantCulture), Convert.ToDouble(y, System.Globalization.CultureInfo.InvariantCulture)), Symbol = LayoutRoot.Resources["QuakePictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol }; graphic.Attributes.Add("MAGNITUDE", magnitude); graphicsLayer.Graphics.Add(graphic); } } } } } private void UseLinq(Stream s) { GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; graphicsLayer.ClearGraphics(); XDocument doc = XDocument.Load(s); XNamespace geo = "http://www.w3.org/2003/01/geo/wgs84_pos#"; var rssGraphics = from rssgraphic in doc.Descendants("item") select new RssGraphic { Geometry = new MapPoint( Convert.ToDouble(rssgraphic.Element(geo + "long").Value, System.Globalization.CultureInfo.InvariantCulture), Convert.ToDouble(rssgraphic.Element(geo + "lat").Value, System.Globalization.CultureInfo.InvariantCulture)), Symbol = LayoutRoot.Resources["QuakePictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol, RssAttributes = new Dictionary<string, object>() { { "MAGNITUDE", rssgraphic.Element("title").Value } } }; foreach (RssGraphic rssGraphic in rssGraphics) { foreach (KeyValuePair<string, object> rssAttribute in rssGraphic.RssAttributes) { rssGraphic.Attributes.Add(rssAttribute.Key, rssAttribute.Value); } graphicsLayer.Graphics.Add((Graphic)rssGraphic); } } internal class RssGraphic : Graphic { public Dictionary<string, object> RssAttributes { get; set; } } }}
