Wondering if someone could tell me if Arcpad 10.2 is compatible with Arcmap 10.3?
Hola Preston,
I understand you wanted to know if ArcPad 10.2 is compatible with ArcMap 10.3, and the answer is Yes. ArcPad is an independent model, there’s no ‘compatibility’ needed between it and ArcMap. The only component that is related to ArcMap is the ArcPad Data Manager, where it will leverage the Check Out/In data component. This can be used overall with just about any supported versions of ArcMap (ArcMap 10.0-10.3x). I hope this addresses your question but we are here to assist if you have any further questions or issues. Gracias, Preston!
Juan
Preston, make sure to mark Juan's answer as correct. This will close the thread and make it easier for others to find the answer. It should be a green star by his answer (if viewing thru the geonet inbox, may need to open in a new tab).
Yes it does. Thank you very much
in terms of the data it collects? It would be best if you saw the page itself, since it only cites whether it can use data from arcmap, which of course means that it is version free, if you are just using the data.
http://www.esri.com/software/arcgis/arcpad/common-questions
PS moving this to ArcPad where you might get more information and other resources
