You will certainly need to restart the listener; the need for a database bounce is less likely. Unfortunately, you can't prototype all possible problems as thought experiments -- At some point you need to try it in your dev server, and see how it works out.- V
The process should be the same, but setting environment variables can't be doneat a server level in Unix, and some of the newer Oracle releases seem to clear the environment to avoid security pitfalls, so you need to make sure PEDATAHOME is being set correctly (before the service start request), and that it's still available when necessary (might need to be set explicitly in the listener files).- V
According to this article, http://resources.arcgis.com/en/help/main/10.1/index.html#/ST_Transform/006z0000009s000000/, to apply file-based CRS transformation in using sde.st_transform function, need to copy the ArcGIS pedata folder to the database server and setup environmental variable PEDATAHOME on the database server. It gives an example for databases on Windows. I am wandering if anybody has done this for SDE database on Linux and what else needs to be done. Does the database instance needs to be rebounced or the listener needs some extra configuration?
