Error while adding symbol resource
I am using SilverLight API v 2.0 with VS 2010 and whenever I add a resource for symbol I get the following error:
Error 1 The "ValidateXaml" task failed unexpectedly.
System.IO.FileNotFoundException: Could not load file or assembly 'System.Runtime.Serialization, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e' or one of its dependencies. The system cannot find the file specified.
File name: 'System.Runtime.Serialization, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e'
at System.ModuleHandle.ResolveType(RuntimeModule module, Int32 typeToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount, ObjectHandleOnStack type)
at System.ModuleHandle.ResolveTypeHandleInternal(RuntimeModule module, Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)
at System.Reflection.RuntimeModule.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments)
at System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, RuntimeModule decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, IRuntimeMethodInfo& ctor, Boolean& ctorHasParameters, Boolean& isVarArg)
at System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeModule decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes, Boolean isDecoratedTargetSecurityTransparent)
at System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeType type, RuntimeType caType, Boolean inherit)
at System.RuntimeType.GetCustomAttributes(Type attributeType, Boolean inherit)
at MS.Internal.Xaml.Schema.ClrType.GetCustomAttribute(Type attrType)
at MS.Internal.Xaml.Schema.ClrType.LookupRuntimeNameProperty()
at MS.Internal.Xaml.Schema.ClrType.LookupPropertyValue(NonBoolTypeValidBits typeBit)
at MS.Internal.Xaml.Schema.ClrType.get_RuntimeNamePropertyCore()
at MS.Internal.Xaml.Parser.XamlAttribute.Initialize(XamlParserContext context, XamlType ownerType, XamlNamespace ownerNamespace)
at MS.Internal.Xaml.Parser.XamlScanner.PostprocessAttributes(XamlScannerNode node)
at MS.Internal.Xaml.Parser.XamlScanner.ReadObjectElement(XamlName name, Boolean isEmptyTag)
at MS.Internal.Xaml.Parser.XamlScanner.ReadElement()
at MS.Internal.Xaml.Parser.XamlScanner.DoXmlRead()
at MS.Internal.Xaml.Parser.XamlScanner.Read()
at MS.Internal.Xaml.Parser.XamlPullParser.<P_PropertyElement>d__31.MoveNext()
at MS.Internal.Xaml.Parser.XamlPullParser.<P_ElementBody>d__23.MoveNext()
at MS.Internal.Xaml.Parser.XamlPullParser.<P_Element>d__7.MoveNext()
at MS.Internal.Xaml.Parser.XamlPullParser.<P_ElementContent>d__39.MoveNext()
at MS.Internal.Xaml.Parser.XamlPullParser.<Parse>d__0.MoveNext()
at MS.Internal.Xaml.TextReaderEnumerator.MoveNext()
at MS.Internal.Xaml.XamlTextReader.Read()
at MS.MarkupCompiler.ValidationPass.ValidateXaml(String fileName, Assembly[] assemblies, Assembly callingAssembly, TaskLoggingHelper log, Boolean shouldThrow)
at Microsoft.Silverlight.Build.Tasks.ValidateXaml.XamlValidator.Execute(ITask task)
at Microsoft.Silverlight.Build.Tasks.ValidateXaml.Execute()
at Microsoft.Build.BackEnd.TaskExecutionHost.Microsoft.Build.BackEnd.ITaskExecutionHost.Execute()
at Microsoft.Build.BackEnd.TaskBuilder.ExecuteInstantiatedTask(ITaskExecutionHost taskExecutionHost, TaskLoggingContext taskLoggingContext, TaskHost taskHost, ItemBucket bucket, TaskExecutionMode howToExecuteTask, Boolean& taskResult)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
EsriMapApp
