I can't figure out how to update the Array associated with a Key in the Dictionary. I don't have a problem parsing the CSV file; each line has a Rhino Name (which will be the key in the Dictionary) and associated X & Y values. I am also able to created the Dictionary with the Rhino Name as Key as associate an Array with each Key. The problem is when I try to ".add" the new point to the Array all the Arrays get overwritten with the new Added point. At the end I have 5 Key:Array associations but the Array are all the same points/tracks.As each line of the CSV file is read how do I add the new point to the Array in the dictionary associated with that specific Key, without messing up the Arrays/Points in the other Arrays? The output will be to a feature class which has already been created. The feature class will show "tracks" of five different Rhinos. Right now all five of my records end up with all the same polylines, but they should all be different, consisting only of the a associated points for each Rhino. Here is a portion of the CSV file I'm working with:Observer,X,Y,Rhino,CommentsBen,26.99391,-19.10447,Bo,Ben,27.00071,-19.1089,Tulip,BathingBen,26.9919,-19.10511,Bo,Ben,27.00071,-19.1059,Tulip,Ben,26.96809,-19.09578,Patches,Ben,26.97808,-19.11016,Dinky,Ben,26.99213,-19.10395,Bo,Ben,27.00083,-19.10326,Tulip,
# Open CSV file containing Rhino track points
trackPointsPath = "C:\wcgis\GEOG485\Project_4\RhinoObservations.csv"
trackPoints = open(trackPointsPath, "r")
# Read first line of CSV file, strip "new line" and make Python List of Header titles
headerLine = trackPoints.readline()
headerLine = headerLine.rstrip("\n")
splitHeaderLine = headerLine.split(",")
# Get index for needed Header fields
indexPointX = splitHeaderLine.index("X")
indexPointY = splitHeaderLine.index("Y")
indexRhinoName = splitHeaderLine.index("Rhino")
# Create an empty dictionary. Each key will be Rhino Name & values points Array.
dictionaryRhinoTracks = {}
# Loop through each line in the CSV file & split with delimiter ","
for line in trackPoints.readlines():
line = line.rstrip("\n")
splitLine = line.split(",")
print splitLine
# Create variable for needed field items based on index position
pointX = splitLine[indexPointX]
pointY = splitLine[indexPointY]
rhinoName = splitLine[indexRhinoName]
# Create a Point object
currentPoint = gp.createobject("Point")
currentPoint.X = pointX
currentPoint.Y = pointY
# Check if the Dictionary contains Name, if yes pass, else createobject Array and add to the dictionary
if rhinoName in dictionaryRhinoTracks:
pass
else:
rhinoTrackArray = gp.createobject("Array")
dictionaryRhinoTracks[rhinoName] = rhinoTrackArray
# Check Keys in Dictionary and add Point Object (X & Y coordinates) to the Array
for key in dictionaryRhinoTracks:
if key == rhinoName:
rhinoTrackArray.Add(currentPoint)]
cursor = gp.InsertCursor(featureClassName)
row = cursor.NewRow()
for rhinoName in dictionaryRhinoTracks:
row.Shape = rhinoTrackArray
row.Rhino_Name = rhinoName
cursor.InsertRow(row)
Thank you for any guidance. Darcy
