Was also going to add I using the code found here and can not find an example of where this actually works.http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htmI also run the code below, height is generated as an integer usually between 150 and 250 based on content of the infowindow. This parts below run without the map.infoWindow.setFixedAnchor(esri.dijit.InfoWindow.ANCHOR_LOWERLEFT) part which seems to act as an unknown function.map.infoWindow.resize(220, height);map.infoWindow.show(point);
