I have an application that generates routes and stops built in .net using the REST API and managed to generate all json, but I don't know how to draw on the map the json "out_routes" and "out_stops".
Any idea?
Thanks!
I know this is late but I return the data that comes back from: SolveVehicleRoutingProblem/jobs/{{jobId}}/results/out_Routes?token=...On the frontend I have JS that looks like:
//store all routes var polyArr = []; //make line for (var route of routes) { var polyline = { type: "polyline", paths: route.geometry.paths }; //make symbol var polylineSymbol = { type: "simple-line", // autocasts as SimpleLineSymbol() color: [50, 50, 50], width: 4 }; //Put it together in a Graphic object let polylineGraphic = new Graphic({ geometry: polyline, symbol: polylineSymbol, attributes: polylineAtt, popupTemplate: {...} }) //Add route object to route array polyArr.push(polylineGraphic); } //route layer is a graphic layer that was previously added to the map routeLayer.addMany(polyArr);
Hope this helps someone.
