This part of code is what I have written based on the "Create an offline map" Guide:
Map theMap = new Map(new Uri(_configService.ServerConfiguration.SigMapUrl));
OfflineMapTask task = await OfflineMapTask.CreateAsync(theMap);
Envelope areaOfInterest = theMap.Item.Extent;
GenerateOfflineMapParameters parameters = await task.CreateDefaultGenerateOfflineMapParametersAsync(areaOfInterest);
parameters.MaxScale = 3000;
OfflineMapCapabilities results1 = await task.GetOfflineMapCapabilitiesAsync(parameters);
DependencyService.Get<IFileService>().CreateLocalDBFolder(App.CurrentConfigName);
string pathToOutputPackage = DependencyService.Get<IFileService>().CreateLocalDBFolder(App.CurrentConfigName+"/Sig");
DependencyService.Get<IFileService>().EmptyFolder(pathToOutputPackage);
GenerateOfflineMapJob job = task.GenerateOfflineMap(parameters, pathToOutputPackage);
GenerateOfflineMapResult results2 = await job.GetResultAsync();
When I run this part of code, a dialog opens in middle of the process that asks to me to give login and password to get acces to tiled basemap.
What sort of code should I add to avoid this dialog opening and to give these information (login and password) hard-coded in code ?
And I have a second question, concerning this part of code. Downloading the tiles from the server can be a long operation. Is there some ways to have a sort of progress event to give some UI progress on interface (% of downloading for exemple) ?
Regards.
