Hi all,
I want to change Attachment's title (see Pic.) I know how to override CSS defaults, but what to do with DIV elements i do not know.
Any help please
The code I posted was tested and working. Not sure why you added the first css rule you posted above.
Aaah, i used 4.14 version, switch to 4.15 it works. Thanks my friend
Robert,
I tried but it did not work.
But if i do it like i show in this code, it changes ATTACHMENTS color, but title stays same.
div<SPAN class="punctuation token">.</SPAN>esri<SPAN class="operator token">-</SPAN>feature__attachments<SPAN class="operator token">-</SPAN>title <SPAN class="punctuation token">{</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Blah Blah"</SPAN><SPAN class="punctuation token">;</SPAN> color<SPAN class="punctuation token">:</SPAN>#dc2d5e<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>indent<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> display<SPAN class="punctuation token">:</SPAN> block<SPAN class="punctuation token">;</SPAN> line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> initial<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esri<SPAN class="operator token">-</SPAN>feature__attachments <SPAN class="operator token">></SPAN> h2 <SPAN class="punctuation token">{</SPAN> text<SPAN class="operator token">-</SPAN>indent<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN>9999px<SPAN class="punctuation token">;</SPAN> line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>esri<SPAN class="operator token">-</SPAN>feature__attachments <SPAN class="operator token">></SPAN> h2<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">:</SPAN>after <SPAN class="punctuation token">{</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Blah Blah"</SPAN><SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>indent<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> display<SPAN class="punctuation token">:</SPAN> block<SPAN class="punctuation token">;</SPAN> line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> initial<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Vakhtang,
This is a real hack but it allows you to replace the text inside a css rule:
<SPAN class="selector token">.esri-feature__attachments > h2</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">text-indent</SPAN><SPAN class="punctuation token">:</SPAN> -9999px<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">line-height</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.esri-feature__attachments > h2::after</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">content</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Blah Blah"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">text-indent</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> block<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">line-height</SPAN><SPAN class="punctuation token">:</SPAN> initial<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
