Hi, i am trying to currently working on a assignment that would require me to perform geocoding against a JSON object containing a array of addresses. im looking at using python to achieve this functionality. Initial research on arcgis api has yielded little results so i was wondering is there anyone on the forum can point me in the correct direction? is it do-able?ps. im a complete newbie to python, just picked up the language a few days ago so go easy on me guys~
You're going to want to tackle this problem using regular expressions. There may already be modules out there written to parse JSON objects. You'll need to hunt around a bit.http://docs.python.org/2/library/re.html
HiRegexes are a wormhole you might not want to dive into.The canonical approach to geocoding an array of addresses would be to write them into a table (a text file is OK, provided it has recognised delimiters and header) and geocode the table.Regards
HiArcPy recordsets (and featuresets) can be converted to and from JSON using the .JSON and .AsShape methods, so that part is easy, within a script or model embedding a script. You can geocode a recordset (treat it like a table in other words) or load it into an in_memory table to geocode it.If you are using ArcGIS Online there is a REST endpoint for batch geocoding, but don't go down that track unless you need to.http://resources.arcgis.com/en/help/arcgis-online-geocoding-rest-api/Regards
